Nois thinkdiag mini can fd scanner
It does turn off on this video. See second 28 off this video
You are right, well observed, I managed to communicate with mine, but when recording the firmware my stlink had a communication problem and there was an error and now I can no longer communicate, I believe there was a lack of power at the time because I was using a battery moto and my stlink-utility I believe to be having problems because it gave a lot of USB communication errors, would you have the stlink-utility to run with the clone?It does turn off on this video. See second 28 off this video
Try firmware update on the ST-Link then power cycle the VCI with the button depressed (green light off) and re-tryYou are right, well observed, I managed to communicate with mine, but when recording the firmware my stlink had a communication problem and there was an error and now I can no longer communicate, I believe there was a lack of power at the time because I was using a battery moto and my stlink-utility I believe to be having problems because it gave a lot of USB communication errors, would you have the stlink-utility to run with the clone?
is it your board?where is swdio and swclk in this board Посмотреть вложение 3840
I've already updated the stlink firmware and changed versions of the program, but I'll keep trying, if you could post the stlink-utility you use it would be of great value for me to test, thanks for your feedback and thanks in advance my friend.Try firmware update on the ST-Link then power cycle the VCI with the button depressed (green light off) and re-try
where is swdio and swclk in this board ?
carbugs.ru
Спасибо большое за информацию. По thinking mini. Всё получилось работает на Дз отличноis it your board?
For this board, the Flashing is done successfully. However the bluetooth is not found/connected in DZ app. If try to connect in android bluetooth settings, it gives a PIN/Password error and doesnt pair.
а раньше этот адаптер работал ? Может bluetooth вышел из строя после разборки , ковыряли компаунд ?anyone knows the solution to this problem?
I have 20 pcs.а раньше этот адаптер работал ? Может bluetooth вышел из строя после разборки , ковыряли компаунд ?
But some of those 20 still work fine?However all of the are not working on Bluetooth pairing.
No, none of them are working.But some of those 20 still work fine?
